Forssux
(Guy Forssman)
April 8, 2025, 3:21pm
1
Hi There,
Inside my configuration.yaml I have…
- platform: sql
db_url: !secret maria_URL
query: SELECT COUNT(*) AS state FROM states WHERE metadata_id = 1198
column: "state"
unit_of_measurement: "rows"
I restart HA 2025.4.1 nothing shows up in the developer states section under the name tester
I searched with phpMyAdmin also nothing
There is nothing mentioned in the logs
The maria_URL is used for the recorder and that works.
I tried some variations '," and no quotes helas
I tried to get info from here
can somebody throw me a bone?
tom_l
April 8, 2025, 11:59pm
2
Compare your config (in sensors.yaml):
- platform: sql
name: tester counter...
to the example shown in the documentation you linked to (in configuration.yaml):
sql:
- name: Sun state
query: >...
The SQL sensor is not a sensor platform. It is its own integration that goes in configuration.yaml, not sensors.yaml.
Forssux
(Guy Forssman)
April 9, 2025, 12:22pm
3
Indeed Tom was right…
Although I thought it was a sensor and belonged in the sensor it stood on his own.
# Loads default set of integrations. Do not remove.
default_config:
recorder:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
extra_module_url:
- /hacsfiles/lovelace-card-mod/card-mod.js
script: !include scripts.yaml
scene: !include scenes.yaml
smappee:
client_id: Guy Forssman
client_secret: !secret smappee_secret
sql:
- name: tester_counter
query: >-
column: "state"
- platform: history_stats
entity_id: sensor.pixel_7_guy_steps_sensor
state: "total"
type: time
end: "{{ today_at() }}"
duration:
hours: 24
tom_l
April 9, 2025, 12:44pm
4
If you have a lot of them there’s nothing stopping you using an include to put them in their own file.
