This is a short summary to show how to create a table with content from the SQL database in lovelace UI.
Example:
- Create a entity in SQL integration
Open Settings/Devices/Integration search for SQL integration.
Create an entity containing a SQL statement. It must return a JSON object and a dummy state object.
This is an example
SELECT 'OK' state,
CONCAT( '[',
GROUP_CONCAT(
JSON_OBJECT(
'day',date_format(day, "%d %b %Y"),
'duration', duration,
'timing', timing,
'outertemperature', outertemperature
) ORDER BY day DESC LIMIT 10
),']') json
FROM dynamic_prices.ha_heatpump_status_temperature
WHERE state = 'Heating' ORDER BY day DESC ;
There are some hints:
- The state topic can have only 255 chars this is most often not enough.
Solution: Provide a dummy state object ( E.g. âOKâ state)
The JSON string is the second sql output. It is stored in an entity attribute. This has a large character limitation - mariadb has a nice feature named âjson_arrayaggâ. It doesnât work in Homeassistant. As a workaround, use the old fashioned way using CONCAT and GROUP_CONCAT
- It makes sense to disable automatic update to prevent permanent SQL traffic. The SQL Integration supports it.
- Ordering and limit can be specified in the GROUP_CONCAT
- Create a markdown card with a content similar to this example
{% set heatpumpstates = state_attr('sensor.ha_heatpump_status','json')|from_json %}
|Tag| Dauer [min]| Taktung|Aussen Temp.|
|:---:|---:|---:|---:|{% for state in heatpumpstates %}
|{{ state.day }}|{{ state.duration }}|{{ state.timing }}|{{ state.outertemperature }}|{% endfor %}
- Optional: If you disabled SQL polling, create an automation to update the entity
Example:
alias: Trigger Heatpump Report
description: Trigger Heatpump Report
triggers:
- trigger: time
at: "00:00"
actions:
- target:
entity_id: sensor.ha_heatpump_status
action: homeassistant.update_entity
data: {}
mode: single
I hope this is interesting to anyone.
