Hi @all,
I’ve got a problem with my HA installation. Maybe someone can help me
Logger: homeassistant.components.recorder
Source: components/recorder/__init__.py:509
Integration: Recorder (documentation, issues)
First occurred: 15:32:35 (711 occurrences)
Last logged: 16:06:07
Error saving events: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2021-02-01 15:06:02.340796', '2021-02-01 15:06:02.340796', 'aa0e4c7dffa46d4a68ad858d52b66102', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
Error saving events: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2021-02-01 15:06:03.326173', '2021-02-01 15:06:03.326173', '323ea78b551ab9579e2384a4e1335693', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
Error saving events: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2021-02-01 15:06:04.696397', '2021-02-01 15:06:04.696397', '09b2052952c4cd85f184f3a055420b0f', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
Error saving events: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2021-02-01 15:06:05.588817', '2021-02-01 15:06:05.588817', '6e96528ca4ea5afeb14e95be9e6bdbec', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
Error saving events: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?)] [parameters: ('state_changed', '{}', 'LOCAL', '2021-02-01 15:06:06.612305', '2021-02-01 15:06:06.612305', 'bafd55d417267afb5a4d433eaa645af8', None, None)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1276, in _execute_context
self.dialect.do_execute(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/default.py", line 593, in do_execute
cursor.execute(statement, parameters)
sqlite3.DatabaseError: database disk image is malformed
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 454, in _commit_event_session_or_retry
self._commit_event_session()
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 509, in _commit_event_session
self.event_session.flush()
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py", line 2536, in flush
self._flush(objects)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py", line 2678, in _flush
transaction.rollback(_capture_exception=True)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/langhelpers.py", line 68, in __exit__
compat.raise_(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/compat.py", line 182, in raise_
raise exception
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py", line 2638, in _flush
flush_context.execute()
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/unitofwork.py", line 419, in execute
n.execute_aggregate(self, set_)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/unitofwork.py", line 521, in execute_aggregate
self.execute(uow)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/unitofwork.py", line 586, in execute
persistence.save_obj(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/persistence.py", line 239, in save_obj
_emit_insert_statements(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/persistence.py", line 1135, in _emit_insert_statements
result = cached_connections[connection].execute(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1011, in execute
return meth(self, multiparams, params)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/sql/elements.py", line 298, in _execute_on_connection
return connection._execute_clauseelement(self, multiparams, params)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1124, in _execute_clauseelement
ret = self._execute_context(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1316, in _execute_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1510, in _handle_dbapi_exception
util.raise_(
raise exception
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
[parameters: ('service_registered', '{"domain": "recorder", "service": "purge"}', 'LOCAL', '2021-02-01 14:21:00.856055', '2021-02-01 14:21:00.856055', 'a054514238ee9876a6380d6d25c27343', None, None)]
