Squeezebox integration is broken
I upgraded to 0.110.2 and my squeezebox media players do not populate anymore. I believe the adjustments made to make HA load up quicker may be to blame but I’m not sure. Everything with the LMS server outside of HA works fine so I’ve narrowed it down to an HA issue. I see this in my log
Setup of media_player platform squeezebox is taking over 10 seconds.
Failed communicating with LMS: <class ‘concurrent.futures._base.TimeoutError’>
There’s been a couple of big changes to that integration, take a look at the updated docs and make sure your setup is still valid.
The changes are in the release notes, but you have to expand the ‘all changes’ bit at the bottom to see them.
