Is it possible to get a ssh console within home-assistant? I tried to find the answer - but keep getting something simliar referenced for hass.io.
You want to be able to ssh in to your Home Assistant server? That is dependent on your OS.
Yes and no.
I want a SSH console within the HA interface.
Similiar to this, available with hass.io: https://github.com/hassio-addons/addon-ssh
That add-on is built with:
So you could just install it and set your iframe
This isn’t really possible especially for those running on Windows hosts
We do not tend to assume Windows hosts because Home Assistant is not supported on Windows as a host, except in a guest VM.
Thanks - I’ll look into this, might be a solution.
