I am trying to install the ssh & web terminal add-on but I run to the following error, extract from the log:
[00:57:20] NOTICE: Session sharing has been disabled!
/var/run/s6/etc/cont-init.d/user.sh: line 93: l: command not found
[00:57:20] FATAL: Failed executing init command: l
[cont-init.d] user.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
my configuration is as follows:
ssh:
username: homeassistant
password: ''
authorized_keys: XXXX
sftp: false
compatibility_mode: false
allow_agent_forwarding: false
allow_remote_port_forwarding: false
allow_tcp_forwarding: false
zsh: true
share_sessions: false
packages: []
init_commands: ls -la
I would appreciate your help
many thanks
ioannis
