i’m starting fresh install of hass.
the integration of certificat expiry do not work :
2020-01-29 17:40:15 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/src/homeassistant/homeassistant/components/cert_expiry/config_flow.py", line 50, in _test_connection
get_cert, host, user_input.get(CONF_PORT, DEFAULT_PORT)
File "/usr/src/homeassistant/homeassistant/components/cert_expiry/helper.py", line 13, in get_cert
with ctx.wrap_socket(sock, server_hostname=address[0]) as ssock:
File "/usr/local/lib/python3.7/ssl.py", line 423, in wrap_socket
session=session
File "/usr/local/lib/python3.7/ssl.py", line 870, in _create
self.do_handshake()
File "/usr/local/lib/python3.7/ssl.py", line 1139, in do_handshake
self._sslobj.do_handshake()
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1076)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 123, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 160, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 50, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 89, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 130, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 172, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/cert_expiry/config_flow.py", line 79, in async_step_user
if await self._test_connection(user_input):
File "/usr/src/homeassistant/homeassistant/components/cert_expiry/config_flow.py", line 60, in _test_connection
if "doesn't match" in err.args[0]:
TypeError: argument of type 'int' is not iterable
