SSL connection could not be established
Hi.
Help is needed
On 11/30/2025, my Home Assistant suddenly rebooted 2 times (Telegram message), after which I cannot connect to it via cloud access.
“I can’t connect to the Home Assistant
An error was found: The SSL connection could not be established, make sure that your certificate is valid.”
There is no local connection option. How can I fix the error remotely?
