SSL error when accessing SSH & Web Terminal add-on through DuckDNS
I’ve followed all docs on setting up a duckdns address and using ssl to access the SSH & Web Teminal add-on. I can access the unsecured URL, but the SSL URL gives the following error:
Secure Connection Failed
An error occurred during a connection to xxx.duckdns.org:7681. SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the web site owners to inform them of this problem.
Port forwarding is setup on my router for the port this add-on requires, duckDNS is setup, add-on config is setup (ssl = true).
Do I have to add anything to the http: section of home assistant’s configuration.yaml file? I already have one entry in it for the hass.io front end web interface that lets me log into hass.io using an SSL based URL
