Stability of the floor plan
Maybe it’s easier to understand this way: /local/ points to the same location as /www/. So /www/plantegning/plantegning.png in your file explorer is the same as /local/plantegning/plantegning.png in your card config.
i have deleted the >- part and then tried to restart the system.
yes i am sure that the file is actually called plantegning.png and it has the pic in the folder and can open it just as in /config/plantegning/plantegning.png. AND i just want to say thank you so much for the help!! it worked now after restart the system and i didn’t had to open file editor first, it just came as i wished it did and works as i wished for. so thank you so much for the help! :pray: aaanndd for your patient! :hugs: :joy:
fleskefjes, yes but in the script i have used /local/folder/file as boheme61 said, so now i have restarted the system and see if it now understand the script. but since i might use /www/ for other project later on, then i want to create “local” as the root. so i have folders in local and then it is easier for me to always remember local first, then folder and at the end the file i need :slight_smile: but thank you very much for helping out :pray:
Yes, /local/ is the correct way to point to /www/ in your card config (it is not a script). You do not need to create “local as the root”, just use /www.
