Starlink in bypass mode with UDM Pro
Trying to set this up for the first time today. I am able to access the starlink dishy via the 192.168.100.1:9200 address but when adding the integration, I also get unknown error occurred.
Logger: aiohttp.server
Source: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:481
First occurred: 17:44:03 (5 occurrences)
Last logged: 17:46:45
Error handling request from 172.16.6.112
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 510, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 41, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 233, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 121, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 336, in async_configure
    result = await self._async_configure(flow_id, user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 383, in _async_configure
    result = await self._async_handle_step(
        flow, cur_step["step_id"], user_input
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 487, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/starlink/config_flow.py", line 30, in async_step_user
    if uid := await self.get_device_id(url=user_input[CONF_IP_ADDRESS]):
  File "/usr/src/homeassistant/homeassistant/components/starlink/config_flow.py", line 49, in get_device_id
    response = await self.hass.async_add_executor_job(get_id, context)
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
  File "/usr/local/lib/python3.13/site-packages/starlink_grpc.py", line 742, in get_id
    status = get_status(context)
  File "/usr/local/lib/python3.13/site-packages/starlink_grpc.py", line 724, in get_status
    return call_with_channel(grpc_call, context=context)
  File "/usr/local/lib/python3.13/site-packages/starlink_grpc.py", line 631, in call_with_channel
    return function(channel, *args, **kwargs)
  File "/usr/local/lib/python3.13/site-packages/starlink_grpc.py", line 719, in grpc_call
    resolve_imports(channel)
  File "/usr/local/lib/python3.13/site-packages/starlink_grpc.py", line 564, in resolve_imports
    importer.resolve_lazy_imports(channel)
  File "/usr/local/lib/python3.13/site-packages/yagrc/importer.py", line 335, in resolve_lazy_imports
    _lazy_importer.configure(channel, filenames=filenames)
  File "/usr/local/lib/python3.13/site-packages/yagrc/importer.py", line 201, in configure
    loaded = self.reflector.load_protocols(channel, filenames=filenames)
  File "/usr/local/lib/python3.13/site-packages/yagrc/reflector.py", line 114, in load_protocols
    raise ServiceError(response.error_response.error_message)
yagrc.reflector.ServiceError: proto: not found
Heya,
Just following up my post from a week ago, I have just updated to v2025.6.1 and the Starlink integration worked immediately.
I had tested it again just prior to this update and changed nothing network wise so this update seems to have resolved the issue.
Same for me. Latest HA update and it now works after reloading integration from new
