I looked at my home-assistant.log.1 and found this errors. As I am all new to this I wounder if someone could help out on what it means and what I should do. All assistance would be very much appreciated.
This is the log:
2022-12-17 00:22:57.989 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-17 00:22:57.993 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nordpool which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-17 00:23:24.890 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform nordpool is taking over 10 seconds.
2022-12-17 00:23:24.938 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2022-12-17 00:23:24.941 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2022-12-17 00:23:24.944 WARNING (MainThread) [homeassistant.setup] Setup of schedule is taking over 10 seconds.
2022-12-17 00:23:24.947 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2022-12-17 00:25:13.330 ERROR (MainThread) [frontend.js.latest.202212130] http://homeassistant.local:8123/lovelace-hansson/default_view:0:0 Uncaught
2022-12-17 01:34:09.684 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/1f3d020e_run_on_startup_addon/stats request
2022-12-17 01:34:09.775 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 1f3d020e_run_on_startup_addon:
2022-12-17 01:34:09.778 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_vscode/stats request
2022-12-17 01:34:09.781 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_vscode:
2022-12-17 01:34:09.784 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2022-12-17 01:34:09.786 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for cebe7a76_hassio_google_drive_backup:
2022-12-17 01:34:09.789 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_ssh/stats request
2022-12-17 01:34:09.791 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_ssh:
2022-12-17 01:34:09.794 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-12-17 01:34:09.824 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-12-17 01:34:09.827 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mariadb/stats request
2022-12-17 01:34:09.830 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mariadb:
2022-12-17 09:12:23.176 ERROR (MainThread) [homeassistant.components.ipp.coordinator] Error fetching ipp data: Invalid response from API: Timeout occurred while connecting to IPP server.
2022-12-17 09:18:23.681 ERROR (MainThread) [homeassistant.components.ipp.coordinator] Timeout fetching ipp data
2022-12-17 10:28:32.085 ERROR (MainThread) [frontend.js.latest.202212130] http://homeassistant.local:8123/lovelace/0:0:0 Uncaught
2022-12-17 11:23:17.336 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /homeassistant/restart request Server disconnected
Thanks for all help
Ingemar
