Does have HA Startup and shutdown scripts ?
I installed HA on a PC and when i reboot or shutdown HA
Ist Not going off or rebooting. I want to find out on which
Scripts Stucks a reboot/shutdown
Create automations that are triggered by startup and shutdown events.
You can also use an Event Trigger to listen for the following three events:
Thank you for your Answer.
But i am looking for Scripts during System starting. Linux Haus for Exempel /etc/rc……
In this folder are Scripts there loading Network, vga…. And so on.
Dose have HA the Same Scripts for shutdown and startup
Which installation method did you use to install Home Assistant?
If you used Home Assistant OS then it wasn’t meant for users to modify it at the operating system level.
Good question which Version. I Go the way with
Ubuntu Stick, Boot From this, Download und install on the PC………
Go to Settings > System > Repairs
Click the overflow menu (three vertical dots) in the upper right corner and select System Information
What does it indicate next to Installation Type?
Version | core-2023.9.1 |
Installationstyp | Home Assistant OS |
You have Home Assistant OS which is designed to operate as an appliance and not meant for users to customize the workings of its operating system.
Thank you for this info
