I’ve been experimenting with home automation that allows non-technical users to create rules based on state (e.g., “run vacuum when house is empty”). It’s surprisingly intuitive when simplified.
Given that Nabu Casa focuses on privacy and local control, I’m curious: have you explored state-based automation? If not, what’s the constraint—UX complexity, technical debt, low demand, or something else?
Asking because I’m considering whether this is a real gap or a problem only I see.
Nabu Casa offers a remote cloud-based connection ( Among other things ) to Home-assistant installs
HomeAssistant Cloud
Not to be “Confused” with i.e Homeassistant OS
Which above also explain, Nabu Casa, basically contribute with i.e features in regards to accessibility
Not Common Automation features or the likes
Automations is triggered by i.e entity-state, events, time etc (sort of state/state-change)
There might me a Real gap, in your Understanding of HA, and therefore You apparently see a non-existing problem
PS: to get you started a simple search in here would most likely have given you an answer
( Do have in mind that the Automation-grafic-editor has just gone through some major changes, like i.e " Based on the very thing you seems to look for , release-20266/#purpose-specific-triggers-and-conditions… " , but still have the “old” ways for those with deeper(old) knowledge and needs for details )
PS: There are several solution/topic made for Vacuum when nobody’s Home, in this simple search https://community.home-assistant.io/search?q=run%20vacuum%20when%20nobody%20is%20home
Not in the way OP means. They are Event based. The State and Numeric State triggers (and their derivatives) are based on the Event of a state changing. Other triggers can be based on the event of time changing or that of services being called.
What does Nabu Casa’s “focus on privacy and local control” have to do with Home Assistant triggering automations based on events instead of state-polling? The one doesn’t follow from the other.
Home Assistant has been using this methodology longer than Nabu Casa has existed.
Topics similar to this come up a few times a year on these forums, usually from new users coming from other systems. Feel free to use the search function to find them.
For most users this does not seem to be a significant “gap” or “problem”, just a difference in approach.
