Version: core-2026.1.3
Installation type: Home Assistant OS
card-mod 4.1.0
I have not been able to get state dependent icon and icon color to “adjust” using card-mod.
My intent is to show a red door-open or a green door-closed icon based on door status:
type: tile
entity: binary_sensor.u_bolt_pro_z_wave_smart_lock_current_status_of_the_door
icon: >
{{ 'mdi:door-open' if
is_state('binary_sensor.u_bolt_pro_z_wave_smart_lock_current_status_of_the_door',
'on') else 'mdi:door-closed' }}
vertical: false
features_position: bottom
card_mod:
style: >
ha-card { --paper-item-icon-color: {{ 'red' if
is_state('binary_sensor.u_bolt_pro_z_wave_smart_lock_current_status_of_the_door','on')
else 'green' }}; }
No error messages in the system log or when I open the card with the visual or code editor.
I have at least 2 problems to resolve: icon selection and icon color. Neither of my approaches in the YAML above work.
Any suggestions would be appreciated. Thank you.
(duck.ai got me this far, but I need a bit more help )
You cannot use jinja templates here, the Tile card does not support them.
If the “binary_sensor” entity has a “device_class = door” - then it will have a proper icon automatically.
No need to use card-mod - if you the entity has a “device_class = door” (see above) then these colors can be defined in a custom theme:
state-binary_sensor-door-on-color: red
state-binary_sensor-door-off-color: cyan
But of course you can use card-mod:
card_mod:
style: |
ha-card {
--state-binary_sensor-door-on-color: red;
--state-binary_sensor-door-off-color: cyan;
If the entity has no “device_class = door” - a common way can be used:
card_mod:
style: |
ha-card {
{% if is_state(config.entity, 'on') -%}
--card-mod-icon-color: ...;
--card-mod-icon: ...;
{%- else -%}
{%- endif %}
Has no sense since the Tile card does not support features for “binary_sensor” entities.
YetAnotherDave:
Outdated some time ago (a year? two years?).
Thank you so much.
Yes: device_class = door
I’ve uninstalled card-mod and created this theme:
# Themes
frontend:
themes:
doorcolor:
state-binary_sensor-door-off-color: green
Oddly, I deleted those lines many times, but every time I re-edited the YAML those lines reappeared. No worries, I’ve deleted that ill-fated attempt altogether.
Closed:
Open:
as desired… thanks again!
