Sensors Offline
{% for state in states.sensor -%}
{% if state.state == ‘down’ %} {{ state.attributes.friendly_name }} {{‘\n’}} {% endif %}
{%- endfor %}
Really ? “my state”.is.state.with an extra state. “mystate”.state.state.
Make it make sense.
{%- endfor %}
Make it make sense.
The first state is the state object which has a lot more information than just its .state.
Using a keyword as a variable like this will make you insane. Just use another word.
While I agree with SG that it’s best to avoid using keywords as variables, I don’t understand what you are actually complaining about…?
FWIW, you can get the same results without the for loop by using the built-in filters:
{{ states.sensor | selectattr('state', 'eq', 'down')
| map(attribute='name') | list | join('\n') }}
My preferred one is
{% for StateStateOfStates in states.sensor -%}
{% if StateStateOfStates.state == ‘down’ %} {{ StateStateOfStates.attributes.friendly_name }} {{‘\n’}} {% endif %}
{%- endfor %}
Just love that long variable name.
But luckily for you, you can choose anyone you want.
You used state and apparently you didn’t like that.
So what about just s?
{% for s in states.sensor -%}
{% if s.state == ‘down’ %} {{ s.attributes.friendly_name }} {{‘\n’}} {% endif %}
{%- endfor %}
Thanks for the responses people.
I have to be honest I picked this gem up somewhere on the interwebz and it just confused the hell out of me.
I am a 3 rate template jockey, so basically an idiot. I get by with the simple things. But these answers cleared up a LOT!
Especially this: “Using a keyword as a variable like this will make you insane. Just use another word.” I misunderstood that part completely.
Thank you!
