State_image in picture-entity doesn't allow spaces?
Hi all,
I’ve setup a picture-entity in lovelace to have a look of Air Quality, here’s the code:
      - type: picture-entity
        entity: sensor.aqicn
        title: Air Quality
        state_image:
          "Buona": /local/airquality/qualitabuona.jpg
          "Moderata": /local/airquality/qualitamoderata.jpg
          "Insalubre per alcuni": /local/qualitainsalubreperalcuni.jpg
          "Insalubre": /local/airquality/qualitainsalubre.jpg
          "Molto insalubre": /local/airquality/qualitamoltoinsalubre.jpg
          "Pericolosa": /local/airquality/qualitapericolosa.jpg
I noticed that if state is on “Insalubre per alcuni” which has spaces the image is not loaded. It is a issue or maybe an error in my config?
Thank you in advance!
Put your paths in quotes and it will work
        title: Air Quality
        state_image:
          "Buona": "/local/airquality/qualitabuona.jpg"
          "Moderata": "/local/airquality/qualitamoderata.jpg"
          "Insalubre per alcuni": "/local/qualitainsalubreperalcuni.jpg"
          "Insalubre": "/local/airquality/qualitainsalubre.jpg"
          "Molto insalubre": "/local/airquality/qualitamoltoinsalubre.jpg"
          "Pericolosa": "/local/airquality/qualitapericolosa.jpg"
EDIT: I just noticed that you are referring to the state. That should work… What does sensor.aqicn state in the states page during that state?
at the moment this is the state:
Entità
sensor.aqicn
State
State attributes (JSON, optional)
  "friendly_name": "Qualità dell'aria a Torino"
Ah, I think I found your issue. Are you missing a part of your path?
          "Insalubre per alcuni": "/local/airquality/qualitainsalubreperalcuni.jpg"
You’re right!!!
Thank you very much!
