tbar05
January 21, 2019, 7:36am
1
is it possible to use a mdi icon in a picture elements card in lovelace like the below:
entity: cover.aeotec_zw062_garage_door_controller_barrier_state_label
show_name: false
show_state: false
state_image:
open: 'mdi:garage'
tap_action: toggle
type: picture-entity
i can seem to get the correct format
You can use the “icon element”
You can do it with CSS:
- type: state-icon
entity: binary_sensor.door_window_sensor_158d1231d8525b
style:
top: 33%
left: 65%
'--paper-item-icon-active-color': red
tbar05
January 21, 2019, 7:56am
4
the icon element doesnt change dependent on state tho. i want to have different mdi icon for different states
You can achieve this with another way:
Create a tempate cover for your cover and use your custom icons for on and off and then use that template cover into your lovelace.
tbar05
January 21, 2019, 10:30am
6
ive set up the template in my config.yaml, but when i go to put that template cover into lovelace, what do i do it as?
A state-icon would do the work and also show the changes based on the icons you setup on the template.
This allows me to adjust most that I want. I only wish I could select a mdi: icon.
Anyone know how?
icon: mdi:lamp
does not work.
type: state-icon
tap_action:
action: toggle
entity: light.lr_lt_tv
style:
top: 40%
left: 51%
–iron-icon-height: 30px
–iron-icon-width: 30px
–paper-item-icon-color: gray
–paper-item-icon-active-color: yellow
You can try using the config-template-card to customize icon card, here is our code:
- type: custom:config-template-card
entities: [light.family]
card:
type: custom:hui-picture-elements-card
image: /local/mainfloor.png
elements:
- type: icon
icon: "${if (states['light.family'].state === 'on') 'mdi:lightbulb-on';else 'mdi:lightbulb-outline'}"
tap_action:
action: toggle
entity: light.family
style:
top: 70%
left: 70%
color: "${if (states['light.family'].state === 'on') 'red';else 'gray'}"
--iron-icon-height: auto
--iron-icon-width: 4vh
This will change both color and icon based on the entity state.
Thanks, will take a look.
OK, Have it installed and configured for one entity. No errors, but no floorplan. Blank page.
Using same .png file and location as original that worked. Is " hui-picture-elements-card" included or is there another .js file to install?
Please share your code so we can take a look.
ok thanks just modified your example for local entity.
entities: [light.lr_lt_wndw]
card:
image: /local/pics/floorplan.png
elements:
- type: icon
tap_action:
action: toggle
entity: light.lr_lt_wndw
style:
top: 70%
left: 70%
color: "${if (states['light.lr_lt_wndw'].state === 'on') 'red';else 'gray'}"
Try change light.family to your light.lr_lt_wndw in icon:
icon: “${if (states[‘light.family’].state === ‘on’) ‘mdi:lightbulb-on’;else ‘mdi:lightbulb-outline’}”
Sorry, I did miss that one. Yes that did it.
Now to add 55 lights and 21 cameras.
I am sure I will have issues with syntex… Any other examples around?
Thanks for helping with this…
Great, I have a ton to convert also myself
Is there anyway to use the entities variable (or set another) so the same entity does not have to be typed in 3 times?
Having strange results. The first entity(light) works normal ON = Red OFF = outline icon.
But the 2nd, 3rd, and 4th lights turn ON but icon does not turn Red and will not turn OFF. If any of them (2-4) are ON and light 1 is turned ON its icon turns Red and the others that are ON also turn Red… Reverse is true for Off. The first entity seems to influences the 2nd-4th ones.
I just copied the codes from the 1st for the other 3 and changed the entities.
Wonder if the other Picture-Element Card is interfering.
entities: [light.lr_entrnc_lt]
card:
elements:
- type: icon
icon: "${if (states['light.lr_entrnc_lt'].state === 'on') 'mdi:lightbulb-on';else 'mdi:lightbulb-outline'}"
tap_action:
action: toggle
entity: light.lr_entrnc_lt
style:
top: 40%
left: 43%
color: "${if (states['light.lr_entrnc_lt'].state === 'on') 'red';else 'gray'}"
--iron-icon-width: 3vh
- type: icon
icon: "${if (states['light.lr_lt_kit'].state === 'on') 'mdi:lightbulb-on';else 'mdi:lightbulb-outline'}"
tap_action:
action: toggle
entity: light.lr_lt_kit
style:
top: 31%
left: 43%
color: "${if (states['light.lr_lt_kit'].state === 'on') 'red';else 'gray'}"
- type: icon
icon: "${if (states['light.lr_lt_wndw'].state === 'on') 'mdi:lightbulb-on';else 'mdi:lightbulb-outline'}"
tap_action:
action: toggle
style:
top: 31%
left: 51%
- type: icon
icon: "${if (states['light.lr_lt_tv'].state === 'on') 'mdi:lightbulb-on';else 'mdi:lightbulb-outline'}"
tap_action:
action: toggle
style:
top: 40%
left: 51%
color: "${if (states['light.lr_lt_tv'].state === 'on') 'red';else 'gray'}"
You need to add all the lights to the entities:
entities: [light.lr_entrnc_lt,light.lr_lt_kit,… ]
Or use
entities: [group.all_lights]
for all lights.
Thanks again. That did it.
