State Timeline Card for Home Assistant
A Lovelace card that queries the HA recorder and walks step-by-step through state transitions for a set of selected entities over a time range. Each step shows every selected entity's current state, previous state, and how long it had been there. The entity whose change triggered the step is highlighted.
Functions:
- Select any combination of entities (by device or individually)
- Set a time range โ presets (10m, 15m, 20m, 24h) or arbitrary
- Step forward/backward through every state change in the window
- Expand any row to view the full attribute JSON at that step
- Mark a start and end step, export the slice as JSON
- Load a previous export into a side-by-side twin stepper for visual comparison
Use cases:
Derived-state sensors. When the state you care about isn't a single entity but a combination โ "dishwasher actually finished," "vacuum stuck mid-run," "garage open with no car." Capture a known instance, read the multi-entity signature off the export, build a template or trigger-based binary_sensor.
Integration porting. Capture canonical events on a known device, side-by-side against a new device via the twin stepper, map analog entities to a canonical event grammar.
Sample signature โ Eufy vacuum clean-completion:
binary_sensor.alfred_chargingoff โ on (dock contact)- +2002ms
vacuum.alfredreturning โ docked - +2003ms
sensor.alfred_task_statusReturning โ Completed - +2003ms
sensor.alfred_work_modeRoom โ unknown - +2032ms
binary_sensor.alfred_active_run_has_erroron โ off
Install: HACS custom repository: kingchddg901/ha-state-timeline-card
Repo + docs: GitHub - kingchddg901/ha-state-timeline-card: Developer-focused Lovelace card for stepping through HA recorder state transitions across multiple entities ยท GitHub
Limitations:
- Desktop only
- Bound by recorder retention (
purge_keep_days); warns before searches that exceed it - No automated diff between live and reference timelines; comparison is visual by design
