I feel like I am missing some fundamentals when it comes to understanding how to make a triggered sensor.
I want to create a new sensor that tracks the state of another sensor, but only updates if the state has been consistent for 10 minutes.
This is what I have (which doesn’t work):
- trigger:
- entity_id: binary_sensor.boiler_on
to: "on"
for: "00:10:00"
to: "off"
for: "00:10:00"
binary_sensor:
- name: boiler on sticky
state: "{{binary_sensor.boiler_on}}"
icon: mdi:water-boiler
Which causes an error to be thrown which states
Invalid config for 'template' at configuration.yaml, line 102: required key 'trigger' not provided
Could someone tell me what I need to do to get this to work? I can’t seem to figure out what the formatting should be for this thing… Also, if someone could point me to something that explains how to understand this, I would really like to get better at it.
Thanks!
I tried reading the examples on that page before I posted. I did manage to get it to work, but I’m not sure I understand why/how…
- trigger:
- trigger: state
to: "on"
for: "00:10:00"
- trigger: state
to: "off"
for: "00:10:00"
binary_sensor:
I don’t think you did… "{{binary_sensor.boiler_on}}"
will not return anything useful. You need to use the states()
function to get the value of the entity’s state.
It’s also possible to do what you want without triggers by using the delay_on
and delay_off
configuration keys.
- binary_sensor:
state: "{{ is_state('binary_sensor.boiler_on', 'on') }}"
delay_on: "00:10:00"
delay_off: "00:10:00"
Thank you!
I had figured out that I didn’t get it working, only that I got it to not throw errors.
The solution you suggest is much more elegant. Thank you!
I’m gonna implement my sensor as you suggest, but for my own education, would this work?
- trigger:
- trigger: state
to: "on"
for: "00:10:00"
- trigger: state
to: "off"
for: "00:10:00"
binary_sensor:
state: >-
{{ states('binary_sensor.boiler_on') }}
Yes, or you could also use the trigger
variable instead of re-querying the state:
- trigger:
- trigger: state
- "on"
- "off"
to:
- "on"
- "off"
for: "00:10:00"
binary_sensor:
state: "{{ trigger.to_state.state }}"
Thank you.
You have been very helpful
