Statistics are gone after update to 2025.11.0
Hi all, just upgraded my HA to 2025.11.0 and all my statistics were purged. Restored the backup of the morning.
No one else seems to be reporting that problem.
Next time you update check your logs and Developer Tools → Statistics.
Same issue here “no statistics found” but “show more” shows that there is history available. Also the energy dashboard stoped recording its empty for few days now. Version 2025.11.1. Logs show only warnings for recorder no errors.
What about Developer Tools → Statistics?
Are there Fix Issue buttons next to your entities?
I have waited till the 2026.11.1 upgrade. I did not had the problem of lost statistics anymore, but I had new issues: the config directory was gone or not visible anymore and the Samba add-on didn’t worked anymore. So I’ve rolled back to 2026.10
Yes a lot, i will check that thank you, but update to 2025.11.2 fixed the issue for me and i also got the data back in the energy dashboard for the days that didn’t show data since the issue started.
When things like this happen you need to collect data to work out why it happened, before you roll back to a previous version.
I didn’t had time to do that. I cannot afford a long downtime and did therefor a rollback as it was obvious the system was not OK. If there is no config dir also not hidden, what kind of data do you advice I should collect?
Logs.
Hi!
I have the same problem, but I am already at version 2025.11.3 (Core) and my statistcs didnt come back.
Is here something new?
