apparently on may 20th at 5 am I uses 1909 m3 of gas
which is more then I use in a year.
when I check the database I see this
where “state” is the actual state of consumed gas.
and Sum seems to be some kind of calculation which is in line with the actual state.
however, at some point this calculation failed.
how can I fix this one?
update statistics
set sum = sum - 1909.something
where metadata_id=15
and id >= 1201844
or will that one break something? or are there better ways to fix this? and also how to avoid this issue in the future?
