Statistics Graph Card calibrated values from adc sensor
So I have 2 values from esphome.
Pulse_width using lambda to correct the value displays ok in graph card, but adc using calibration filter displays raw voltage level in graph instead of calibrated value.
Entities card displays both values in ppm as expected.
Any suggestions how to set up so that graph card shows both in ppm? Or should I use lambda expression for adc also.
  - platform: adc
    pin: 34 #<----------------pin
    unit_of_measurement: ppm
    update_interval: 5s
    filters:
      - calibrate_linear:
          # Point 1 -> 0.4V (from sensor) to 0.0    ppm (true value)
          # Point 2 -> 2.0V (from sensor) to 5000.0 ppm (true value)
          - 0.4 -> 0.0
          - 2.0 -> 5000
  - platform: pulse_width
    pin: 18 #<----------------pin
    update_interval: 5s
    filters:
      - lambda: return x*5000-10;
It shouldn’t. What you have is correct. The filter should transform the value sent to home assistant. If it is not doing that you should open an issue.
Thanks for reply!
I’ll do that.
Discussion continues here:
