Step-by-step for adding UZB to RPi4
Hi all,
Very first days of Home Assistant here - and I’m completely lost. So sorry for my very beginner question, but hopefully you can guide me in the right direction. I’m definitely not a programmer.
I’m running HA and trying to add my first z-wave devices to play around with. To control them I’ve bought a UZB from z-wave.me and added that stick to one of the USB ports in my RPi.
But then what: I’m completely lost on the next steps here.
I’ve tried to go to HA > Integrations > Add Integration but getting this error:
What am I missing here? I found this ID in HA > Supervisor > Host System > Hardware, but I have no idea about if it’s the right one.
Any help will be greatly appreciated - thanks!
Not 100% sure but the serial port doesn’t work with this way of adding the Z-Wave integration. I think /dev/ttyACM0 works here, and the /dev/serial port can only be set up through the configuration.yaml
Again, not 100% sure of the above statement, but doesn’t hurt to try :slight_smile:
If you plugged in the USB stick while HA was already running, you probably need to restart it.
