Since I have problems with the latest version of HA Core: 0.110.1, I would like to downgrade to 0.109.6.
When I enter the command
core downgrade --version=0.109.6
in the cli, the process starts and ends successfully.
When I login to the GUI of home assistant, the developer info still shows 0.110.1 as running version.
The OS log shows the following:
20-05-22 09:11:45 ERROR (MainThread) [supervisor.homeassistant] Home Assistant has crashed!
20-05-22 09:11:45 CRITICAL (MainThread) [supervisor.homeassistant] HomeAssistant update fails -> rollback!
20-05-22 09:11:45 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.110.1
20-05-22 09:11:45 INFO (SyncWorker_2) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.109.5 to homeassistant/qemux86-64-homeassistant:0.110.1
20-05-22 09:11:45 INFO (SyncWorker_2) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.110.1.
20-05-22 09:11:46 INFO (SyncWorker_2) [supervisor.docker.interface] Clean homeassistant application
Any help?
