Still on 0.114.4 due to a need for kiosk mode (lost with Custom Header)
I have a tablet that uses Custom Header’s user-agent string to assign a profile that doesn’t show any header at all - kiosk mode.
Is there anything out there that does that? I know from reading here that card-mod is an option but I didn’t think it had that same functionality.
Thanks!
There is a replacement for that feature: https://github.com/maykar/kiosk-mode
And small header is now available in Core as well.
So, you can have the same look in 2020.12 that you have in 0.114.4.
Thank you! Massive help.
Sure it’s a small issue but I can’t find Kiosk Mode in HACs at all! Very odd. Is it because I still have custom header installed? Or my version of HA is too low? Didn’t think HACs made those checks?
The doc says:
If you previously used custom-header you need to uninstall it from HACS
I just did that… So, I don’t know. It worked.
Weird. It’s not there on a totally different instance without Custom Header either! @mayker am I being stupid?! Thanks!!
HACS -> Frontend -> Bottom right add button -> search for "kiosk"
