My sprinkler system is integrated in HA. In order to run multiple sprinkler zones in succession, I use an input boolean which activates an automation. See below.
However, I want to configure it in a way where I can stop the entire automation mid-run if the input boolean is turned off. Is there a simple way to do that? Would I need a seperate automation? Any suggestions would be great.
alias: "Sprinklers: Frontyard (Right - Front)"
description: Runs Sprinkler Zones 1, 2 for 10 minutes
mode: single
triggers:
- entity_id:
- input_boolean.sprinklers_frontyard_right_front
to: "on"
trigger: state
conditions: []
actions:
- action: switch.turn_on
entity_id: switch.rain_bird_sprinkler_1
data: {}
- delay: "00:10:00"
- action: switch.turn_off
data: {}
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
entity_id: switch.rain_bird_sprinkler_2
data: {}
- delay: "00:10:00"
data: {}
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- action: input_boolean.turn_off
metadata: {}
data: {}
entity_id: input_boolean.sprinklers_frontyard_right_front
You could add a second trigger when the input Boolean is turned off and change the automation mode to restart. Use trigger ids and a choose block to run the actions. The off trigger block would turn off the sprinklers.
So something like this?
description: Runs Sprinkler Zones 1, 2 for 10 minutes unless cancelled
mode: restart
- id: start
platform: state
to: "on"
- id: stop
platform: state
to: "off"
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: switch.turn_on
- delay: "00:10:00"
- service: switch.turn_off
- delay: "00:00:30"
- delay: "00:10:00"
- delay: "00:00:30"
- service: input_boolean.turn_off
- conditions:
sequence:
entity_id:
- switch.rain_bird_sprinkler_1
- switch.rain_bird_sprinkler_2
123
(Taras)
April 17, 2025, 9:13pm
5
Have you considered what may happen if Home Assistant is restarted during the first or second 10-minute delay
The reason why I ask is because then Home Assistant is restarted, all active automations are immediately terminated. In other words, they do not run to completion but are stopped at whatever action they are currently executing (in the middle of a 10-minute delay
) and do not execute their remaining actions (like turning off the sprinkler).
You may wish to test this potential failure scenario by restarting Home Assistant while the automation is executing its 10-minute delay
tom_l
April 17, 2025, 11:36pm
6
I use the weekly schedule helper to time my irrigation. If I want to stop a run it is simply a matter of turning off the valve switch.
- id: 9249ec91-acda-4885-9d11-ecb51bf51416
alias: Irrigation Zone 1 # Ferns
triggers:
- trigger: state
entity_id: schedule.fern_tricklers_schedule
to: 'on'
conditions:
- condition: state
entity_id: binary_sensor.fern_moisture_limit
state: 'off'
actions:
entity_id: switch.zone_1
- action: notify.telegram_system_log
title: '💧 <b>Z1 Irrigation on</b>'
message: "Fern irrigation turned on."
- id: 4e688d37-95c5-4724-b950-bb0b40389c99
alias: Irrigation Zone 1 Off # Ferns
triggers:
- trigger: state
to: 'off'
conditions:
- condition: state
state: 'on'
actions:
title: '☑️ <b>Z1 Irrigation off</b>'
message: "Fern irrigation turned off."
I also have a couple of failsafes:
- id: abb3d2f7-e567-44c3-930f-7d438910b62d
alias: Irrigation Time Overrun
triggers:
- trigger: state
to: 'on'
for:
minutes: "{{ states('input_number.max_run_time')|int }}"
variables:
- trigger: state
entity_id: switch.zone_2
to: 'on'
for:
variables:
- trigger: state
entity_id: switch.zone_3
to: 'on'
for:
variables:
actions:
title: '⚠️ <b>Irrigation Max Runtime</b>'
message: "Turning off {{name}} irrigation due to max runtime ({{ states('input_number.max_run_time') }} min). Please check valve, controller, and schedule if this was not a manual activation."
entity_id: "switch.zone_{{ trigger.id|int + 1}}"
- id: 575d6820-6e39-41bb-8186-db4215031fe2
alias: 'Irrigation Connection Monitor'
triggers:
- trigger: state
entity_id: binary_sensor.irrigation_status
to: 'off'
for:
minutes: 5
actions:
- action: notify.telegram_alert
title: '⚠️ <b>Irrigation lost comms</b>'
message: "Communication lost to irrigation controller. Please check valves are not on."
