Home Assistant 2023.8.4
Supervisor 2023.09.2
Operating System 10.5
Frontend 20230802.1 - latest
I have not seen an update for anything since the Home Assistant 2023.8.4 update. Does anyone have any ideas? I have not been able to find anything online to help me. Where do I start? Did I turn something off?
Settings → System → Repairs
There are currently no repairs available
Settings → System → Logs.
Possibly the supervisor logs.
Here are the Supervisor Logs:
23-09-29 09:00:10 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-09-29 09:02:12 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-09-29 09:06:01 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-09-29 09:10:40 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/zigbee2mqtt/hassio-zigbee2mqtt repository
23-09-29 09:10:40 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-09-29 09:10:40 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-09-29 09:10:40 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-09-29 09:10:45 INFO (MainThread) [supervisor.store] Loading add-ons from store: 75 all - 0 new - 0 remove
23-09-29 09:36:01 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-09-29 10:02:12 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-09-29 10:06:02 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-09-29 10:36:02 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-09-29 10:44:11 INFO (MainThread) [supervisor.host.info] Updating local host information
23-09-29 10:44:12 INFO (MainThread) [supervisor.host.services] Updating service information
23-09-29 10:44:12 INFO (MainThread) [supervisor.host.network] Updating local network information
23-09-29 10:44:12 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-09-29 10:44:12 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-09-29 11:00:10 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-09-29 11:02:12 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-09-29 11:02:13 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-09-29 11:02:13 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-09-29 11:02:13 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-09-29 11:06:03 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-09-29 11:36:03 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
Whoa! I clicked on “HACS” and updated it. Then I had to reboot. When it came back up, there was a notification for 2023.9.3 waiting for me.
It would seem that if I had just rebooted my RPi, then it would have sorted itself out. Yeesh. How embarrasing.
Thank you for paying some attention to my post. I hope that my experience can help someone else. “When in doubt, reboot.”
Don’t confuse reboot and restart though. They are two different things.
Restart: restart a service like Home Assistant, everything else like the OS and add-ons keeps running.
Reboot: reboot the host device, everything stops and restarts HA, OS, add-ons, everything. You should very rarely ever have to do this. Genrally only after an OS update.
