Hi, I have just finished installing HAOS on a Dell Wyse 5070 thin client. This is my first time trying Home Assistant and im pretty happy to have got it up and running, even got a Sonoff Zigbee USB E-variant up and running with Zigbee2qtt.
So to my issue. I got 1 notification under Settings. Its 1 Repair. If I click on it i get the following:
Storage corruption detected for bluetooth.passive_update_processorCritical ⸱ Reported by Home Assistant Core Integration
The bluetooth.passive_update_processor storage could not be parsed and has been renamed to /config/.storage/bluetooth.passive_update_processor.corrupt.2025-04-29T20:37:35.909455+00:00 to allow Home Assistant to continue.
A default bluetooth.passive_update_processor may have been created automatically.
If you made manual edits to the storage file, fix any syntax errors in /config/.storage/bluetooth.passive_update_processor.corrupt.2025-04-29T20:37:35.909455+00:00, restore the file to the original path /config/.storage/bluetooth.passive_update_processor, and restart Home Assistant. Otherwise, restore the system from a backup.
Select Submit below to confirm you have repaired the file or restored from a backup.
The exact error was: Error while loading /config/.storage/bluetooth.passive_update_processor: Input is a zero-length, empty document: line 1 column 1 (char 0)
Submit
I am totaly new to this and I have no clue what to do to remove the error. Everything seems to work fine, but I would like to fix this in case it will give me trouble down the road.
Try to explain what I need to do like you would to a total noob cus thats what I am atm ![]()
Thanks in advance
