Storage corruption detected
i had issues discovering shelly devices with official Shelly integration after uninstalling shellyforHaas integration. Found “solution” that all i need is to remove shelly entry from a file /config/.storage/core.config_entries. I did as instructed via SSH, but i possibly left symbols because HA did not restart normally and i was greeted that i need to fix error (Error while loading /config/.storage/core.config_entries: trailing comma is not allowed: line 27 column 998 (char 11672)) and then restart. It created new fresh core.config_entries file and broken one renamed to core.config_entries.corrupt.2024-12-05T07:50:39.732046+00:00 but when i try to edit it with “sudo nano” it has no content just a empty file, but the file size says different. When i try to rename broken file with “mv” command i get error No such file or directory. I know its a easy fix when you know how SSH works but im stuck and even don’t know how to google my problem :slight_smile:
PS i made no backups … yeah i know :frowning: but i would like to solve this without making fresh HA
