Storage keeps getting corrupted
My home assistant keeps getting corrupted and I have to restore from backup. This has happened 2 times now, and every time it starts with the bluetooth file being corrupted, and then the core_config_entries.
I will of course restore it again, but is there anything I can do to prevent this from happening again?
I have never touched the files that are corrupted.
How are you running HA ? On what hardware ? Storage ?
I am running it on a Raspberry Pi 4 using an SSD
Is your SSD connected straight to your pi, or do you use a powered hub ?
It is connected straight to my pi with an sata adaptor
That could be the problem. Try with a powered hub, the problem should go away.
