Store calculated values?
Probably a noob question. I have created a number of sensors that are set by automations and calculate a lot of stuff, like energy usage, solar power generated etc. My problem is that the values get ‘lost’ during a restart of HA, wich happens quite a lot since i am always experimenting with it. Can anyone point me in the right direction?
Help would be greatly appreciated!
Take a look at the recorder integration or if you plan on storing the data long term I’d suggest InfluxDB.
Hi Burningstone, thanks for the pointer, sounds like a good idea, do the values stored with recorde automatically reload their last known value after a HA restart?
Recorder and influxdb are databases. They store your calculated values (as the title of your topic asks), but they don’t reload their last value on HA restart. For that you can either use the SQL sensor to retrieve them, or more simple, store them in an input_number.
btw, it’s a very common expectation here.
I recently started monitoring my electricity consumption, and faced a similar problem : having historical data by day of electricity consumed. My ZMAI90 returns total energy used (sensor.mains_consumed_energy). I used the MQTT database to store the calculated values.
Created 2 MQTT sensors :
  - platform: mqtt
    state_topic: "sensor/totalenergy"
  - platform: mqtt
    state_topic: "sensor/yesterday_energy"
Every day at midnight :
- id: '1569740295999'
  alias: Save consumed energy
  - at: '23:59'
    platform: time
  - data:
      payload_template: >
        {{ "%.2f"|format( (states("sensor.mains_consumed_energy") | float) - (states("sensor.total_energy") | float))  }}
      topic: sensor/yesterday_energy
      retain: true
    service: mqtt.publish
  - data:
      payload_template: >
        {{ states("sensor.mains_consumed_energy")}}
      topic: sensor/totalenergy
      retain: true
Since published with the retain flag, they survive a HA restart.
The sensor.yesterday_energy gets pushed to influxdb to generated nice graphs on daily basis.
you publish it to a separate MQTT topic with retain: true, right?
it has some advantages and disadvantages comparing to storing data in input_xxx so in the end of the day it depend on the use case - for example, MQTT allows for as many attributes as you like but you need separate input_xxx to store it, but one have to have MQTT broker up and running and MQTT sensors configured properly.
I know that you know it, just added the note so readers understand their options.
Thanks for your input, makes sense, i am trying to get this working, seems to work, another strange thing: one value is shown as a string (‘0.72’) the other value is an actual number, can you define the type of mqtt sensor (numeric of string)?
Screenshot_1
My config:
- platform: mqtt
  state_topic: "sensor/solarpowerhour"
  unit_of_measurement: kWh
- platform: mqtt
  state_topic: "sensor/solarpowerlastval"
    - service: mqtt.publish
        payload_template: >
          '{% if states.sensor.produced_power_hour_last_val.state | float | round(0) == 0 %}
                    {{0 | float}}
                {% else %}
                    {{(states.sensor.shellyem_b9eabf_total_returned_0.state | float - states.sensor.produced_power_hour_last_val.state | float)| round(2)}}
                {% endif %}'
        topic: sensor/solarpowerhour
        retain: true
        payload_template: >
          {{states.sensor.shellyem_b9eabf_total_returned_0.state | float}}
        topic: sensor/solarpowerlastval
        retain: true
Many thanks!
just remove single quotes around tour first payload_template :wink:
Hey AhmadK, now i feel stupid :wink:
Many thanks, been staring at it for over an hour…
Happy Easter!
in the future paste in into Developer tools - > Templates and you’ll see it
