The summer is coming and Home Assistant got me completely crazy about measuring everything that I can. So, I’ve bought a wood heater for the inflatable pool and have a series of temperature sensors (DS18B20 with ESPHOME) all ready to measure the water temperature. In addition, I have a POWR2 with Tasmota to detect if the pump is running, to make sure the water in the wood heater doesn’t overheat, etc. etc. All big fun!
I detect that the heating has started by seeing the pump power exceeding a threshold and measuring the difference in the actual temperature between water from the pool and water going back to the pool.
The only thing missing, is that I want to calculate how much the temperature increased since I started this session of heating.
In order to do so, I need to ‘store’ the temperature of the water when I started heating as the reference… And that’s where my knowledge runs short.
So, what I’m looking for, is a way to create a sensor in configuration.yaml of which I only update the value when a certain automation in automations.yaml is being triggered.
The idea is, that when I detect the start of heating the pool, I copy the current water temperature value of a sensor to this self-made variable and then simply subtract this stored value from the current temperature to know how much the water heated-up since the start of this heating cycle.
I have an idea how to do all of this, except for copying the current value of a sensor only when it was triggered by an automation. I can’t declare a sensor in configuration.yaml without the value_template included. So, if I do it that way, it keeps overwriting the value with the actual value of the sensor.
Can anyone help me in the right direction to find a solution for this?
