I still use my magicmirror for some home dashboard weather items but want to use HA moving forward. One particular integration I would love is stormglass.io (https://stormglass.io/).
Has anyone been able to successfully pull in data from this site into HA?
Along the docs it produces a json (usual format) and then you can use the restful integration (or if only one the restful sensor)
RESTful - Home Assistant (home-assistant.io)
EDIT: assuming you try the free option, you would just have to set the scan interval to 3 hours
This looks great! I’ll start reading up on RESTful and give this a try. Thank you for your response.
Just to let the general community know, I am working on this code. Once I have this working, I intend on posting my sanitized code here so others can benefit. Absolutely love this community and all the help it provides!
interested in this, how did you get along?
Not yet, distracted with other things at the moment. I am absolutely going to work on this in the near future. I will post my lessons learned here.
