I recently added a usb zwave and conbee II usb dongles to my server as I was moving my devices away from my smartthings setup.
I suspect my HA setup is a common one. I have a linux server that hosts virtualbox instances and HA is installed on its own virtualbox instance.
Within the first few days I noticed a problem, my zwave network would stop working, usually after about 5 hours or so of bootup. After this happened a few times I actually noticed my zwave usb device was missing in my HA virtual host, hence the outage.
I did some googling and suspected my linux O/S may of been putting the usb device to sleep due to inactivity, penny dropped at this point because my zwave network stopped working during the night and when everyone was at work, thus zwave network was pretty much inactive… perhaps because my HA instance runs in virtualbox maybe virtualbox was messing things up when the usb zwave came out of sleep.
So I edited on my virtualbox host the file /etc/default/grub and changed the following line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
to:
GRUB_CMDLINE_LINUX_DEFAULT="quiet usbcore.autosuspend=-1"
then ran grub-update
Just for good measure I did the same on my HA virtual machine too.
Fingers crossed its never happened again.
