Hello everyone! I’m new to the community but have been enjoying HA for the past half year or so.
Brief setup:
- HA is run on a virtual machine inside a Debian, which works on a Lenovo server.
- I’m using Sonoff stick with the latest firmware paired with Zigbee2MQTT, around connected 20+ devices
I have created automation to heat up a towel rack and ventilation when someone showers, so the automation is triggered by a sensor’s humidity attribute.
Until yesterday, the automation worked like a charm, but then I noticed weird behaviour - the second time the automation is run, it does not return the thermostat state back to 10 degrees.
Here’s the full automation config:
alias: If humidity >70% -> boost ventilation until humidity falls below 65%
description: ''
- platform: numeric_state
entity_id: sensor.sensor_yellow_humidity
for:
hours: 0
minutes: 0
seconds: 30
attribute: humidity
above: '70'
condition: []
- type: turn_on
device_id: b7b3bcdaf82ab7f666951ebe52ebaf9a
entity_id: switch.ventilation_3rd_floor
domain: switch
- service: climate.set_temperature
temperature: 26
entity_id: climate.thermostat_black
- delay:
hours: 0
minutes: 6
seconds: 0
milliseconds: 0
temperature: 10
- wait_for_trigger:
for:
hours: 0
minutes: 0
seconds: 0
attribute: humidity
below: 66
timeout:
hours: 0
minutes: 20
seconds: 0
milliseconds: 0
continue_on_timeout: true
- type: turn_off
domain: switch
mode: single
In automation trace everything works fine:
1st automation trace
Executed: April 26, 2023 at 6:56:50 AM
Result:
params:
domain: climate
service: set_temperature
service_data:
temperature: 10
entity_id:
- climate.thermostat_black
entity_id:
running_script: false
limit: 10
In the second too:
Executed: April 26, 2023 at 7:50:22 AM
Result:
params:
domain: climate
service_data:
temperature: 10
entity_id:
entity_id:
limit: 10
But the zigbee2mqtt logs show a different picture (I filtered only thermostat logs):
info 2023-04-26 06:29:58: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":10,"eco_mode":"OFF","eco_temperature":18,"linkquality":47,"local_temperature":21,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"idle","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"CLOSED","window":"CLOSED","window_detection":"OFF"}'
debug 2023-04-26 06:32:10: Received Zigbee message from 'Thermostat black', type 'commandMcuSyncTime', cluster 'manuSpecificTuya', data '{"payloadSize":28169}' from endpoint 1 with groupID 0
debug 2023-04-26 06:40:28: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,200],"type":"Buffer"},"datatype":2,"dp":3}],"seq":3111}' from endpoint 1 with groupID 0
info 2023-04-26 06:40:28: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":10,"eco_mode":"OFF","eco_temperature":18,"linkquality":54,"local_temperature":20,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"idle","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"CLOSED","window":"CLOSED","window_detection":"OFF"}'
#first automation
debug 2023-04-26 06:50:50: Received MQTT message on 'zigbee2mqtt/Thermostat black/set/current_heating_setpoint' with data '26.0'
debug 2023-04-26 06:50:50: Publishing 'set' 'current_heating_setpoint' to 'Thermostat black'
debug 2023-04-26 06:50:50: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,26],"type":"Buffer"},"datatype":2,"dp":2}],"seq":40}' from endpoint 1 with groupID 0
info 2023-04-26 06:50:50: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":26,"eco_mode":"OFF","eco_temperature":18,"linkquality":47,"local_temperature":20,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"idle","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"CLOSED","window":"CLOSED","window_detection":"OFF"}'
debug 2023-04-26 06:50:51: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0],"type":"Buffer"},"datatype":4,"dp":7}],"seq":296}' from endpoint 1 with groupID 0
info 2023-04-26 06:50:51: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":26,"eco_mode":"OFF","eco_temperature":18,"linkquality":43,"local_temperature":20,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"heat","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"OPEN","window":"CLOSED","window_detection":"OFF"}'
debug 2023-04-26 06:56:50: Received MQTT message on 'zigbee2mqtt/Thermostat black/set/current_heating_setpoint' with data '10.0'
debug 2023-04-26 06:56:50: Publishing 'set' 'current_heating_setpoint' to 'Thermostat black'
debug 2023-04-26 06:56:50: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,10],"type":"Buffer"},"datatype":2,"dp":2}],"seq":41}' from endpoint 1 with groupID 0
info 2023-04-26 06:56:50: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK",**"current_heating_setpoint":10**,"eco_mode":"OFF","eco_temperature":18,"linkquality":47,"local_temperature":20,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"heat","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"OPEN","window":"CLOSED","window_detection":"OFF"}'
debug 2023-04-26 06:56:50: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":7}],"seq":297}' from endpoint 1 with groupID 0
info 2023-04-26 06:56:50: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":10,"eco_mode":"OFF","eco_temperature":18,"linkquality":47,"local_temperature":20,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"idle","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"CLOSED","window":"CLOSED","window_detection":"OFF"}'
#end first automation
debug 2023-04-26 07:02:35: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,210],"type":"Buffer"},"datatype":2,"dp":3}],"seq":297}' from endpoint 1 with groupID 0
info 2023-04-26 07:02:35: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":10,"eco_mode":"OFF","eco_temperature":18,"linkquality":61,"local_temperature":21,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"idle","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"CLOSED","window":"CLOSED","window_detection":"OFF"}'
debug 2023-04-26 07:32:40: Received Zigbee message from 'Thermostat black', type 'commandMcuSyncTime', cluster 'manuSpecificTuya', data '{"payloadSize":28937}' from endpoint 1 with groupID 0
*#begin 2nd automation:*
debug 2023-04-26 07:44:22: Received MQTT message on 'zigbee2mqtt/Thermostat black/set/current_heating_setpoint' with data '26.0'
debug 2023-04-26 07:44:22: Publishing 'set' 'current_heating_setpoint' to 'Thermostat black'
debug 2023-04-26 07:44:22: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,26],"type":"Buffer"},"datatype":2,"dp":2}],"seq":42}' from endpoint 1 with groupID 0
info 2023-04-26 07:44:22: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":26,"eco_mode":"OFF","eco_temperature":18,"linkquality":61,"local_temperature":21,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"idle","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"CLOSED","window":"CLOSED","window_detection":"OFF"}'
debug 2023-04-26 07:44:22: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0],"type":"Buffer"},"datatype":4,"dp":7}],"seq":298}' from endpoint 1 with groupID 0
info 2023-04-26 07:44:22: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":26,"eco_mode":"OFF","eco_temperature":18,"linkquality":61,"local_temperature":21,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"heat","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"OPEN","window":"CLOSED","window_detection":"OFF"}'
#reversing back to 10 degrees.
debug 2023-04-26 07:50:22: Received MQTT message on 'zigbee2mqtt/Thermostat black/set/current_heating_setpoint' with data '10.0'
debug 2023-04-26 07:50:22: Publishing 'set' 'current_heating_setpoint' to 'Thermostat black'
debug 2023-04-26 08:00:35: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,220],"type":"Buffer"},"datatype":2,"dp":3}],"seq":298}' from endpoint 1 with groupID 0
*#temperature is still 26*
info 2023-04-26 08:00:35: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK",**"current_heating_setpoint":26**,"eco_mode":"OFF","eco_temperature":18,"linkquality":58,"local_temperature":22,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"heat","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"OPEN","window":"CLOSED","window_detection":"OFF"}'
debug 2023-04-26 08:16:19: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,80],"type":"Buffer"},"datatype":2,"dp":14}],"seq":554}' from endpoint 1 with groupID 0
info 2023-04-26 08:16:19: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":26,"eco_mode":"OFF","eco_temperature":18,"linkquality":61,"local_temperature":22,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"heat","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"OPEN","window":"CLOSED","window_detection":"OFF"}'
debug 2023-04-26 08:16:19: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":9}],"seq":810}' from endpoint 1 with groupID 0
debug 2023-04-26 08:16:19: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0],"type":"Buffer"},"datatype":1,"dp":4}],"seq":1066}' from endpoint 1 with groupID 0
debug 2023-04-26 08:33:10: Received Zigbee message from 'Thermostat black', type 'commandMcuSyncTime', cluster 'manuSpecificTuya', data '{"payloadSize":29961}' from endpoint 1 with groupID 0
debug 2023-04-26 08:42:31: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,230],"type":"Buffer"},"datatype":2,"dp":3}],"seq":1066}' from endpoint 1 with groupID 0
info 2023-04-26 08:42:31: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":26,"eco_mode":"OFF","eco_temperature":18,"linkquality":61,"local_temperature":23,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":25,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"heat","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"OPEN","window":"CLOSED","window_detection":"OFF"}'
debug 2023-04-26 08:42:31: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,75],"type":"Buffer"},"datatype":2,"dp":104}],"seq":1322}' from endpoint 1 with groupID 0
info 2023-04-26 08:42:31: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":26,"eco_mode":"OFF","eco_temperature":18,"linkquality":61,"local_temperature":23,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":75,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"heat","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"OPEN","window":"CLOSED","window_detection":"OFF"}'
*#manual intervention*
debug 2023-04-26 09:09:40: Received MQTT message on 'zigbee2mqtt/Thermostat black/set/current_heating_setpoint' with data '9.0'
debug 2023-04-26 09:09:40: Publishing 'set' 'current_heating_setpoint' to 'Thermostat black'
debug 2023-04-26 09:09:40: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,9],"type":"Buffer"},"datatype":2,"dp":2}],"seq":44}' from endpoint 1 with groupID 0
info 2023-04-26 09:09:40: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":9,"eco_mode":"OFF","eco_temperature":18,"linkquality":61,"local_temperature":23,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":75,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"heat","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"OPEN","window":"CLOSED","window_detection":"OFF"}'
debug 2023-04-26 09:09:41: Received Zigbee message from 'Thermostat black', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":7}],"seq":300}' from endpoint 1 with groupID 0
info 2023-04-26 09:09:41: MQTT publish: topic 'zigbee2mqtt/Thermostat black', payload '{"battery":80,"boost_heating":"OFF","boost_heating_countdown":0,"boost_heating_countdown_time_set":300,"child_lock":"UNLOCK","current_heating_setpoint":9,"eco_mode":"OFF","eco_temperature":18,"linkquality":61,"local_temperature":23,"local_temperature_calibration":0,"max_temperature":45,"min_temperature":5,"position":75,"preset":"manual","programming_mode":"06:00/20°C 11:30/21°C 13:30/22°C 17:30/23°C 06:00/24°C 12:00/23°C 14:30/22°C 17:30/21°C 06:00/19°C 12:30/20°C 14:30/21°C 18:30/20°C","running_state":"idle","system_mode":"heat","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"valve_state":"CLOSED","window":"CLOSED","window_detection":"OFF"}'
debug 2023-04-26 09:33:40: Received Zigbee message from 'Thermostat black', type 'commandMcuSyncTime', cluster 'manuSpecificTuya', data '{"payloadSize":30473}' from endpoint 1 with groupID 0
I notice that in the second run of the automation, I do not get zigbee reply. Is there a way to ensure that zigbee command is executed? Creating automation to check automation sounds crazy, but this is the only solution I see. I also had it before with ventilation that it was not stopping, but it somehow fixed itself.
Any ideas? Thanks in advance!
