I have 3 aircons of Samsung, wich I integrated with Smarthings in HA.
I made an automatisation that switch on these aircons in the morning. Also when I leave my home these aircons shut off and switch back on when I come home.
Sometimes it works fine, but sometimes there is one aircon (not always the same) who didn’t switch on. For the moment I solved it to switch them back on again after 1 minuut
Now I send myself an e-mail when an aircon is switch off or on and I saw a strange thing. In fact, the aircon switch on but immediatly it goes off. Here are my e-mails :
On 7:45 my 3 aircons switch off and on 7:47 they switch back on, but one (Airco living rechts) is switched off again. After 1 minute it is switched on again.
The 2 aircons in my living are switched on within the same script :
- choose:
- conditions:
- condition: state
entity_id: input_boolean.toggle_airco_living
state: 'on'
sequence:
- service: script.switch_airco_x_op_y_graden
temperature: >-
states('input_number.temperatuur_airco_living_tijdens_de_dag')}}
entity_id: climate.airco_living_links, climate.airco_living_rechts
default: []
alias: 'Switch : Airco x op y graden'
description: Set airco mode to heat and set temperature
fields:
temperature:
description: The temperature to set the airco at
default: 22
example: '21'
entity_id:
description: The climate entity you want to control
default: climate.airco_gang
example: climate.airco_gang
sequence:
- service: climate.turn_on
entity_id: '{{ entity_id }}'
- service: climate.set_hvac_mode
hvac_mode: heat
- service: climate.set_temperature
temperature: '{{ temperature }}'
- service: climate.set_fan_mode
fan_mode: auto
mode: single
Any idea ?
