Strange behavior with RGBW neopixel led
All,
I am learning ESPHOME. This is one of my first configuration.
I have setup a neopixel led as follow
light:
  - platform: neopixelbus
    type: GRBW
    variant: 800KBPS
    restore_mode: ALWAYS_OFF
    pin: GPIO22
    num_leds: 11
    effects:
      - addressable_rainbow:
          name: Rainbow Effect With Custom Values
          speed: 10
          width: 50
I have a button that turn it on and off after 60 sec.
binary_sensor:
  - platform: gpio
    pin:
      number: 23
      mode:
        input: true
        pulldown : true
    filters:
      - delayed_on: 10ms
      - delayed_off: 20s
    on_press:
      then:
        - logger.log: "Button is pressed, we'll switch light on"
        - light.addressable_set:
            red: 0
            green: 0
            blue: 0
            white: 60%
        - light.turn_on:
            red: 0
            green: 0
            blue: 0
            white: 60%
Goal is to only light the white led. I have tried percentage, value less than 1, but I always get below when running.
[19:49:51][D][main:235]: Button is pressed, we'll switch light on
[19:49:51][D][light:035]: 'kitchen light' Setting:
[19:49:51][D][light:046]:   State: ON
[19:49:51][D][light:058]:   Red: 100%, Green: 100%, Blue: 100%
[19:49:51][D][light:062]:   White: 60%
[19:49:51][D][light:084]:   Transition length: 1.0s
The odd part is that it wants to turn on the RGB led at 100%, while I don’t want it to happen.
I am unsure what I am doing wrong.
The complete YML is below. It is incomplete, as I am trying to test. The goal is to be able to light a led strip that will have 150 leds on the kitchen countertop. I don’t want to have it at full power
substitutions:
  devicename: kitchen-light-1
esphome:
  friendly_name: kitchen-light-1
esp32:
  board: nodemcu-32s
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: !secret api_key
ota:
  safe_mode: true
  password: !secret ota_key
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "${devicename} Fallback"
    password: !secret fallback_pwd
binary_sensor:
  - platform: gpio
    pin:
      number: 23
      mode:
        input: true
        pulldown : true
    filters:
      - delayed_on: 10ms
      - delayed_off: 20s
    on_press:
      then:
            red: 0
            green: 0
            blue: 0
            white: 60%
        - light.turn_on:
            red: 0
            green: 0
            blue: 0
            white: 60%
    on_release:
        - logger.log: "Button is not pressed anymore, we'll switch light off"
        - light.turn_off:
            transition_length: 10s
  - platform: gpio
    pin:
      number: 18
      mode:
        input: true
        pulldown : true
    device_class: motion
    filters:
      - delayed_on: 10ms
      - delayed_off: 60s
light:
    type: GRBW
    variant: 800KBPS
    pin: GPIO22
    num_leds: 11
    effects:
          speed: 10
          width: 50
I think I got it to work.
Here is what I did
substitutions:
esphome:
esp32:
  board: nodemcu-32s
  framework:
    type: arduino
# Enable logging
logger:
api:
  encryption:
ota:
  safe_mode: true
wifi:
  ap:
binary_sensor:
  - platform: gpio
    pin:
      number: 18
      mode:
        input: true
        pulldown : true
    publish_initial_state: false
    filters:
      - delayed_on: 10ms
      - delayed_off: 20s
    on_press:
      then:
        - if:
            condition:
              light.is_off: kitchenlight
            then :
             - logger.log: "PIR is ON, we'll switch light on"
             - light.turn_on:
                brightness: 90%
                color_brightness: 50%
                red: 0
                green: 0
                blue: 0.2
                white: 80%
    on_release:
      then:
        - if:
            condition:
              and:
                 - light.is_on: kitchenlight
                 - binary_sensor.is_off: onoffbutton
            then :
              - logger.log: "Button is not pressed anymore, light is off and button is off"
              - light.turn_off:
            else:
              - logger.log: "PIR is not ON anymore, but BUTTON is on"
  - platform: gpio
    pin:
      number: 23
      mode:
        input: true
        pulldown : true
    filters:
      - delayed_on: 10ms
      - delayed_off: 20s
    on_press:
      then:
        - if:
            condition:
            then :
             - light.turn_on:
                brightness: 90%
                red: 0
                green: 0
                blue: 0.2
                white: 80%
    on_release:
      then:
        - if:
            condition:
              and:
                 - binary_sensor.is_off: PIRSensor
            then :
              - logger.log: "Button is not pressed anymore, light is off and PIR sensor is off"
              - light.turn_off:
            else:
              - logger.log: "Button is not pressed anymore, but PIR sensor is on"
light:
    type: GRBW
    variant: 800KBPS
    pin: GPIO22
    num_leds: 11
    effects:
          speed: 10
          width: 50
