I’m running Hassio 130 on HassOS 2.2 from an SD card on an Asus Tinkerboard plugged in through ethernet, also tried on an RPi3 with latest release version of HASSOS and HASSIO, also through ethernet.
My Sonos speakers show up as changing their status between off, paused, unavailable every minute.
I also get my logbook and syslog filled with errors related to this and maybe unrelated, but my system crashes every few hours since this is going on.
Cheers,
Peter
2018-09-14 21:55:48 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2018-09-14 21:55:49 ERROR (MainThread) [homeassistant.helpers.entity] Update for media_player.nappali fails
File “/usr/local/lib/python3.6/site-packages/urllib3/connection.py”, line 171, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File “/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py”, line 79, in create_connection
raise err
File “/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py”, line 69, in create_connection
sock.connect(sa)
TimeoutError: [Errno 110] Operation timed out
File “/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 354, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/local/lib/python3.6/http/client.py”, line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/local/lib/python3.6/http/client.py”, line 1285, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/local/lib/python3.6/http/client.py”, line 1234, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/local/lib/python3.6/http/client.py”, line 1026, in _send_output
self.send(msg)
File “/usr/local/lib/python3.6/http/client.py”, line 964, in send
self.connect()
File “/usr/local/lib/python3.6/site-packages/urllib3/connection.py”, line 196, in connect
conn = self._new_conn()
File “/usr/local/lib/python3.6/site-packages/urllib3/connection.py”, line 180, in _new_conn
self, “Failed to establish a new connection: %s” % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0xb21f2d10>: Failed to establish a new connection: [Errno 110] Operation timed out
File “/usr/local/lib/python3.6/site-packages/requests/adapters.py”, line 445, in send
timeout=timeout
File “/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py”, line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host=‘192.168.10.24’, port=1400): Max retries exceeded with url: /ZoneGroupTopology/Control (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0xb21f2d10>: Failed to establish a new connection: [Errno 110] Operation timed out’,))
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 224, in async_update_ha_state
yield from self.async_device_update()
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 353, in async_device_update
yield from self.hass.async_add_job(self.update)
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/media_player/sonos.py”, line 502, in update
self._subscribe_to_player_events()
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/media_player/sonos.py”, line 479, in _subscribe_to_player_events
device.update_groups()
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/media_player/sonos.py”, line 708, in update_groups
elif self.soco.group:
File “/usr/local/lib/python3.6/site-packages/soco/core.py”, line 997, in group
for group in self.all_groups:
File “/usr/local/lib/python3.6/site-packages/soco/core.py”, line 986, in all_groups
self._parse_zone_group_state()
File “/usr/local/lib/python3.6/site-packages/soco/core.py”, line 935, in _parse_zone_group_state
cache_timeout=5)[‘ZoneGroupState’]
File “/usr/local/lib/python3.6/site-packages/soco/services.py”, line 790, in GetZoneGroupState
return self.send_command(‘GetZoneGroupState’, *args, **kwargs)
File “/usr/local/lib/python3.6/site-packages/soco/services.py”, line 477, in send_command
data=body.encode(‘utf-8’)
File “/usr/local/lib/python3.6/site-packages/requests/api.py”, line 112, in post
return request(‘post’, url, data=data, json=json, **kwargs)
File “/usr/local/lib/python3.6/site-packages/requests/api.py”, line 58, in request
return session.request(method=method, url=url, **kwargs)
File “/usr/local/lib/python3.6/site-packages/requests/sessions.py”, line 512, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.6/site-packages/requests/sessions.py”, line 622, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.6/site-packages/requests/adapters.py”, line 513, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host=‘192.168.10.24’, port=1400): Max retries exceeded with url: /ZoneGroupTopology/Control (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0xb21f2d10>: Failed to establish a new connection: [Errno 110] Operation timed out’,))
2018-09-14 21:56:21 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2018-09-14 21:56:23 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.nappali is taking over 10 seconds
