I was advised to check the logs as part of another problem I have. I’ve never checked the logs before, not needed as HA was doing what I expected.
When I checked the Supervisor log I found the following warnings …
2026-01-03 07:56:42.542 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on ‘Traccar’ uses deprecated ‘codenotary’ field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-03 07:56:42.564 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on ‘Grocy’ uses deprecated ‘codenotary’ field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-03 07:56:42.591 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on ‘Folding@home’ uses deprecated ‘codenotary’ field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-03 07:56:42.690 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on ‘InfluxDB’ uses deprecated ‘codenotary’ field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-03 07:56:42.714 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on ‘Log Viewer’ uses deprecated ‘codenotary’ field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-03 07:56:42.747 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on ‘MQTT IO’ uses deprecated ‘codenotary’ field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-03 07:56:42.787 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on ‘Glances’ uses deprecated ‘codenotary’ field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-03 07:56:42.799 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on ‘Nginx Proxy Manager’ uses deprecated ‘codenotary’ field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-03 07:56:42.933 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on ‘Overseerr’ uses deprecated ‘codenotary’ field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2026-01-03 07:56:43.053 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on ‘Tailscale’ uses deprecated ‘codenotary’ field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
These seem to relate to add-ons I’ve not got, and never have had, ( apart from MQTT IO which I played with a few months ago). Most of the add-on names I don’t even recognise. ( I do recognise Tailscale, but it’s something I would never install !. )
What is going on ?
