Strange entry in HOST-Log
Hello everyone,
I have recently noticed the following entry in my HOST log.
2025-03-07 06:59:07.973 homeassistant kernel: nvme nvme0: controller is down; will reset: CSTS=0xffffffff, PCI_STATUS=0x10
2025-03-07 06:59:07.974 homeassistant kernel: nvme nvme0: Does your device have a faulty power saving mode enabled?
2025-03-07 06:59:07.974 homeassistant kernel: nvme nvme0: Try "nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off" and report a bug
2025-03-07 06:59:07.975 homeassistant kernel: nvme 0000:01:00.0: enabling device (0000 -> 0002)
2025-03-07 06:59:07.975 homeassistant kernel: nvme nvme0: 4/0/0 default/read/poll queues
2025-03-07 06:59:07.983 homeassistant kernel: nvme nvme0: Ignoring bogus Namespace Identifiers
Can you tell me what I can do about it or is this completely normal?
This entry is made approx. every 3 minutes.
I had another look today. I think I have found a solution to the problem. On the NVME adapter that plugs directly into the Raspberrypi there was a socket that can be supplied with 5V, I did that and since then there are no longer these entries.
Which power supply/connector did you use? I have the Geekworm X1001 with the white external 5V connector.
https://wiki.geekworm.com/X1001
