Hi guys,
I recently add 8 more GB to my NUC (8+8) cause I want to experiment with docker (nothing to do with HA), after that my HA crashed already twice and I get this error in console
Also I check the logs and this is the logs I got:
2025-02-10 04:13:13.349 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_a0d7b954_ssh application
2025-02-10 04:13:13.956 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/ssh/amd64 with version 20.0.0
2025-02-10 04:13:14.003 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_5c53de3b_esphome application
2025-02-10 04:13:14.783 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/esphome/esphome-hassio with version 2024.12.4
2025-02-10 04:13:14.843 INFO (SyncWorker_7) [supervisor.docker.manager] Cleaning addon_a11dcb03_ha_skill application
2025-02-10 04:13:15.765 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on a11dcb03/amd64-addon-ha_skill with version 1.0.7
2025-02-10 04:13:19.659 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon HA Skill is failed, restarting...
2025-02-10 04:13:19.668 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_a11dcb03_ha_skill application
2025-02-10 04:13:27.710 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_a11dcb03_ha_skill application
2025-02-10 04:13:28.423 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on a11dcb03/amd64-addon-ha_skill with version 1.0.7
2025-02-10 04:13:35.861 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon HA Skill is failed, restarting...
2025-02-10 04:13:35.867 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_a11dcb03_ha_skill application
2025-02-10 04:13:36.198 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-02-10 04:13:36.202 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2025-02-10 04:13:36.511 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on a11dcb03/amd64-addon-ha_skill with version 1.0.7
2025-02-10 04:13:37.884 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon HA Skill is failed, restarting...
2025-02-10 04:13:37.889 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_a11dcb03_ha_skill application
2025-02-10 04:13:38.579 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on a11dcb03/amd64-addon-ha_skill with version 1.0.7
2025-02-10 04:13:39.725 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-1600' coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:1530> exception=AddonsJobError('Rate limit exceeded, more than 10 calls in 0:30:00')>
File "/usr/src/supervisor/supervisor/addons/addon.py", line 1544, in watchdog_container
await self._restart_after_problem(event.state)
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 291, in wrapper
raise on_condition(
f"Rate limit exceeded, more than {self.throttle_max_calls} calls in {self.throttle_period(group_name)}",
supervisor.exceptions.AddonsJobError: Rate limit exceeded, more than 10 calls in 0:30:00
This addon is failing add-on a11dcb03/amd64-addon-ha_skill
and Im not sure what to do.
I read that could be due to insufficient resources but HASS has 4GB and 2 vCPU assigned.
Some tips on how to solve?
