Hi guys,
I getting more and more used to Hass.io and start to love it.
I had a strange experience made in the setup process. I have a motion detector in my hallway which switches the light there automatically on. As I was setting up the hass.io system two times it switched also the lights in the living room on.
Also the presence detection for the staircase light stopped to work as it should be. Instead of switching off after a minute the light stayed on. As I manually switched it off it worked like it should be. Strange: Neither the motion detector nor the presence detector is currently integrated in my hass.io. (the lights yes)
As I want now to integrate my front door, I have an automatic lock, via a MDT Switch I´m a little bit afraid that the door opens up in the middle of the night without someone recognizes it.
My thought was, that through the amount of re-starts and the fact that HA is currently running on a Raspberry 2 was the reason why that could happened. I have to say that since that everything worked fine.
Any Ideas from your side?
Thanks for your support,
Flo
