All was correct I can move cover directly from zigbee2mqtt in sidebar or lovelace
What did you expect to happen
I transferred my hassio to a debian 10 nuc (ACEPC AK1) and recovered a snapshot (ha supervised in docker)
All work fine except
My exposition in zigbee2mqtt is the same and I can move directly cover with state open close
But
in configuration entities the first line is unavailable (red circle with arrow)
Error loading /config/configuration.yaml: while parsing a block mapping
in “/config/configuration.yaml”, line 692, column 5
expected , but found ‘’
in “/config/configuration.yaml”, line 705, column 25
can i mix discovery and manual configuration ?
Someone can help me to write corrects lines
Hi Francis,
thank you for your remarks, which moved me to a write error !
No, I don’t have this line twice but I found the error:
When I opened the file with file editor in HA, I saw that the character (") had disappeared at the end of the line.
availability_topic: "zigbee2mqtt/bridge/state
It appeared however well in notepad ++ which I usually use
but to work I had to indicate the real address of the shutters
Now I tried with pi4+ sdd, same problem. No or incomplete exposition
It is with the snapshot made from pi3 SD who works fine that I have problems with nuc or pi 4 + ssd. Is it a speed or timing problem?
zigbee2mqtt would not communicate well with home assistant in these cases
What do you think ?
I don’t think it’s either of listed potential reasons. I would say it’s discovery issue and/or in conjunction with rollback issue.
Have you performed restart of zigbee2mqtt alone? It usually fixes issues with HA entities.
