Hi folks, I have run into a strange issue with one of my switches. It was the last switch I moved off SmartThings.
I have added it to HA with no problems, and I can control it fine from the UI, the problem I have is that the switch doesn’t do anything in HA. The switch in HA doesn’t turn on/off, and the automation doesn’t trigger. I’m using switch.bedroom_switch to trigger the automation.
It’s a standard GE12722 switch and was working fine in Smartthings, and using MQTT during the transition.
Here are the lines from the entity_registry.yaml file
zwave.bedroom_switch:
config_entry_id:
name:
platform: zwave
unique_id: node-23
switch.bedroom_switch:
config_entry_id:
name:
platform: zwave
unique_id: 23-72057594428604416
