Stream assist crashing HA
I’ve been trying to get View assist running since I saw @dinki put out an integration. I had already gone thru a lot of the setup, browsermod, stream assist, Wyoming etc.
The issue I’m having now is that every time I turn the device’s (Lenovo table) mic on in stream assist HA reboots itself, so it’s basically useless until i can solve that.
specs on my setup:
  • Installation methodHome Assistant OS
  • Core2025.6.1
  • Supervisor2025.05.5
  • Operating System15.2
    Anyone else running into that?
StreamAssist is a bit abandoned. Look for information in the issue section of the project repository.
You can also search for other projects, for example GitHub - jeffc/hassmic: An application for Home Assistant that allows you to use an android device as a voice assist satellite
