Do you mean the stream in the UI player that opens up after clicking the image or when streaming to a chromecast?
Either way, I haven’t noticed any issues but have only watched a few minutes here and there while testing. I was originally testing with lowish settings 960x540, 5fps, 2000 kbps
I’ve since bumped it up to 720p, 15fps, 5000 kpbs and see flashes of green screen with some block distortion in the UI player. Will test these settings to a google home hub this weekend.
**EDIT: ha! google home hub has a max res of 1024x600 so the 720p stream didnt work.
however, vlc on android was able to stream the 720p stream with no green flashes/distortion so perhaps it’s the hsl.js player or something with the ffmpeg was causing the green issues. I’ve not done any other research yet to see if others are having this issue.
I’m back down to 960x540 but now 15fps and 4000kbps to see how it goes…
Log Details (ERROR)
Fri Mar 22 2019 21:25:56 GMT-0400 (Eastern Daylight Time)
blob:https://dffgfgfgfgf.duckdns.org/e6f2208zzzzzzzzzxxssdsdsd:1:2380 Uncaught ReferenceError: s is not defined
Unfortunately I don’t know how to…
I set my authentication to Digest and the Still Image started working, so I assume that is what my camera is using… but I haven’t found a way to pass the credentials with digest auth in the URL.
Just a question, I have those cheap foscam C1 models, what I do, if a put the camera as platform generic in with direct rtsp stream from foscams directly, or stream coming from Synology…
Well it’s sloooooww , just frame a frame… ,Why is that? Why is HA not able to show me a fluent stream?? The stream in Synology surveillance is good! So why not the stream coming from surveillance to HA? Also if I open the same stream in VLC , it’s also fluent?
Enable RTSP by selecting a Camera / Manage / Toggle on RTSP
Copy the RTSP URL
Example: rtsp://192.168.X.X:7447/AbCdeFGhiJK
Log into the camera (via camera IP address)and turn on Enable Anonymous Snapshot*. Checkbox at bottom of config page. Click Save Changes when done. https://192.168.X.X/camera/config
Default Camera username is: ubnt
Password for the camera can be found under the Protect NVR under Settings (Gear icon) / Device Password / Edit
With that information you can now configure it as a generic camera:
