Stream Error
All of a sudden I get the following error after every reboot, anybody have any insight
Source: components/stream/recorder.py:9
First occurred: 4:35:06 PM (1 occurrences)
Last logged: 4:35:06 PM
Error during setup of component stream
  File "/usr/src/homeassistant/homeassistant/setup.py", line 256, in _async_setup_component
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/stream/__init__.py", line 224, in async_setup
    from .recorder import async_setup_recorder
  File "/usr/src/homeassistant/homeassistant/components/stream/recorder.py", line 9, in <module>
    import av
  File "/usr/local/lib/python3.10/site-packages/av/__init__.py", line 20, in <module>
    from av import logging
ImportError: cannot import name 'logging' from partially initialized module 'av' (most likely due to a circular import) (/usr/local/lib/python3.10/site-packages/av/__init__.py)
