I can’t get stream to work because I am unable to install all requirements: av==6.1.2.
python_version | 3.7.3 |
HA version | 0.96.5 |
virtualenv | true |
Raspbian | buster |
ffmpeg | 4.1.3-1+rpt1 |
Unable to install package av==6.1.2: ERROR: Command errored out with exit status 1:
command: /srv/homeassistant_venv/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-kgknpvyf/av/setup.py'"'"'; __file__='"'"'/tmp/pip-install-kgknpvyf/av/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-tv0xww5j --python-tag cp37
cwd: /tmp/pip-install-kgknpvyf/av/
Complete output (53 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.7
creating build/lib.linux-armv7l-3.7/av
copying av/__init__.py -> build/lib.linux-armv7l-3.7/av
copying av/deprecation.py -> build/lib.linux-armv7l-3.7/av
copying av/datasets.py -> build/lib.linux-armv7l-3.7/av
copying av/__main__.py -> build/lib.linux-armv7l-3.7/av
creating build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/player.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/remux.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/__init__.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/average.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/graph.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/second_seek_example.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/experimental.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/decode.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/qtproxy.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/resource_use.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/dump_format.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/frame_seek_example.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/save_subtitles.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/seekmany.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/audio.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/merge-filmstrip.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/glproxy.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/decode_threads.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/encode.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/show_frames_opencv.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/audio_player.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/encode_frames.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/filmstrip.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/cctx_decode.py -> build/lib.linux-armv7l-3.7/scratchpad
copying scratchpad/cctx_encode.py -> build/lib.linux-armv7l-3.7/scratchpad
creating build/lib.linux-armv7l-3.7/av/video
copying av/video/__init__.py -> build/lib.linux-armv7l-3.7/av/video
creating build/lib.linux-armv7l-3.7/av/container
copying av/container/__init__.py -> build/lib.linux-armv7l-3.7/av/container
creating build/lib.linux-armv7l-3.7/av/filter
copying av/filter/__init__.py -> build/lib.linux-armv7l-3.7/av/filter
creating build/lib.linux-armv7l-3.7/av/audio
copying av/audio/__init__.py -> build/lib.linux-armv7l-3.7/av/audio
creating build/lib.linux-armv7l-3.7/av/codec
copying av/codec/__init__.py -> build/lib.linux-armv7l-3.7/av/codec
creating build/lib.linux-armv7l-3.7/av/subtitles
copying av/subtitles/__init__.py -> build/lib.linux-armv7l-3.7/av/subtitles
creating build/lib.linux-armv7l-3.7/av/data
copying av/data/__init__.py -> build/lib.linux-armv7l-3.7/av/data
running build_ext
running config
pkg-config returned flags we don't understand: -pthread -pthread
I followed the instructions in https://www.home-assistant.io/components/stream/#troubleshooting but I get
pkg-config is already the newest version (0.29-6).
python-dev is already the newest version (2.7.16-1).
libavcodec-dev is already the newest version (7:4.1.3-1+rpt1).
libavdevice-dev is already the newest version (7:4.1.3-1+rpt1).
libavfilter-dev is already the newest version (7:4.1.3-1+rpt1).
libavformat-dev is already the newest version (7:4.1.3-1+rpt1).
libavresample-dev is already the newest version (7:4.1.3-1+rpt1).
libavutil-dev is already the newest version (7:4.1.3-1+rpt1).
libswscale-dev is already the newest version (7:4.1.3-1+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Any idea would help.
