Stream webcam card that works with Iphone, via vpn?
I use tailscale (VPN) for HA access and used GitHub - AlexxIT/WebRTC: Home Assistant custom component for real-time viewing of almost any camera stream using WebRTC and other technologies. for setting up a simple card that would stream a camera. It works brilliantly on the local network, but when accessing with tailscale its been very janky, I can see the stream but its not uppdating properly.
Then I found this Exernal access with WebRTC doesn't work · Issue #378 · AlexxIT/WebRTC · GitHub
Is there any setting I can try? Are there any other solutions for showing RTSP streams in this use case?
Calling all cats!
Surely there must be someone with an iphone that wants to watch RTSP streams remote? :slight_smile:
